nickc
Hey
This forum seems to be for advanced designer but I have some basic questions. I need to design a basic small signal amplifier for gain, not LNA or something else...just plain simple gain. I have done the DC analysis (biasing), gain vs. frequency MSG/MAG analysis, and I can easily do matching networks (to 50 Ohms input and output). What I am having trouble with is how to calculate input impedance and output impedance of the transistor (or transistor cells) so that I can match both to 50 Ohms for maximum power gain. Please answer these questions below. Almost of all you can easily answer these in a few minutes, and this will help me out much. Please, if possible, answer each question so as to make it clear for me.
* First of all, does input or output impedance value depend on whether the other port is open or short or connected to a load? I would think not, but I am not sure because of some odd results.
* Does Z11 equal input impedance? If that is true then isn't Z11 calculated with output open (i2=0), but then in actual amplifier output won't be open so how come Z11=input impedance (if it does). This question also relates to the above question.
* The easiest way to calculate input impedance is to do V/I so I placed an AC voltage source (magnitude 1) and read the value of current and took the ratio Zin=1/I to calculate the impedance and I think this value is the correct one. I calculated this with output not open; rather connected to a load (any reasonable size load, 50, 100 or 1000 ohm) or completely shorted. Is this the right way to calculate input impedance? This Zin that I calculated matched Z11 if the output, when calculating Z11, was shorted (which is not the definition of Z11). Also, when I did Zin=V/I with output open and Z11 with output open (which is the actual definition of Z11, i2=0) then these two values matched. If I don't want to do Zin=V/I then what is the right way and setup of measuring Zin using the parameters? As far as I understand, Z11 with i2=0 (open output) does not give you Zin, correct?
* Does S11 or S22 value depend on what source is presented at the input or output? Why? In other words, for example, if I do S22 without matched input and then do S22 with input matched, would these two values of S22 match each other or not?
* Finally, the last question is about LNA. I came across this while looking for answers. In LNA, the input match is not conjugate matched but a source impedance is presented for optimum noise figure. I understand that but then I read that the output is matched based on what source impedance is presented. Why is that, would you just conjugately matched the output impedance to the 50 ohm load to transfer maximum power from outpu to the load? What does that have to do with what source is presented at the input. I know this question might be related to the one above it and answering that one might help me understand this one as well.
I am sure all these question arise from one or two basic underlying concepts. Thank you very much for all your help...Nick
