madmozart
Hi Andrew:
Thanks for your notes. First of all, I'm using Agilent ADS. My S-parameter simulation is just like the standard one, put two 50Ohms ports, and simulate the S parameters. As for the HB simulation, I put a 50Ohm resistor in series with the source and have another 50Ohm resistor as the load. Everything else for the power amplifier is all the same. Yeah, the gain I'm talking about in HB simulation is the power gain, but it shouldn't make any difference, cuz I'm using all 50-Ohms systems. I did the power sweep of input, from -10dBm to +10dBm, and I plotted the gain vs. power. The input power level is as low as -10dBm, and it seems to be the asymptotic value in the lower range since the gain plot is flat with input lower than -5dBm. But still, for the gain with a low input, it doesn't match the gain given by the S-param simulation. I understand that these two simulations are intrisincly different, but when my input power's low, they should be telling the same story, shouldn't they? Confused here! Hopefully you could give me a hint or something. Thanks a lot for your time.
Steve
