Sep 15th, 2026, 5:21pm
period stretcher / expander (Read 2260 times)
trond
Glasgow, Scotland
Jul 27th, 2006, 7:15am
Hello all,
I have a frequency modulated signal. I would like to determine each period of the FM signal, then determine whether it is above or below a reference period. Based on that decision I would like to either multiply this period with a constant factor or divide by it. Having done that I want to generate a new signal based on the determined periods.
In summary,  I would like to amplify the frequency modulation of a FM signal by either increasing or decreasing each period.
I am not even sure whether this can be done with a real circuit. But, at the moment I want to use VerilogA to implement the above.
The period determination and scaling is not an issue. I was wondering how I can create a new signal based on the obtained period information. I guess I need to create 1 period of this new signal, and then add on another just determined new period.
Can anyone suggest a way?
Sven
I am using the following code to determine the periods of a FM signal.
`include "disciplines.vams"
`include "constants.vams"
module fmeasure (in, out);
input in; voltage in;
output out; voltage out;
real last_time, current_time, freq;
analog begin
    @(initial_step)begin
	last_time = 0.0;
	freq = 0.0;
    @(cross(V(in) -0.5, 1)) begin
	current_time = $abstime;
	if (last_time > 0.0)
	    freq = 1.0 / (current_time - last_time);
	last_time = current_time;
 V(out) <+ freq;
jbdavid
Re: period stretcher / expander
Reply #1 - Aug 3rd, 2006, 4:01am
Now that you have your frequency, the rest can be implemented like one of the many VCO models in the examples on this site..
Phase = `m_two_pi * idtmod(Freq_out);
V(Sigout) <+ Amp*sin(Phase);// or cos(phase if you prefer..
jbdavid
