Aug 23rd, 2024, 4:28pm
OP AMP design (Read 9626 times)
amitsingh
Bangalore, India
OP AMP design
Aug 02nd, 2006, 6:24am
Hi Guys,
              I am starting a new topic for discussion inthis forum. So plz help me in sorting my queries.
PLease send me an Op amp design with specs and all the equations for a beginner to start design.
Amit Kumar Singh
View Profile amitsingh_37   IP Logged
Re: OP AMP design
Reply #1 - Aug 2nd, 2006, 7:08pm
You need textbooks, tutorials, and so on.  www.circuitsage.com is a good source for beginners.
If you have more specific questions, you will get more help at the designers guide forum. Smiley
amitsingh
Bangalore, India
Re: OP AMP design
Reply #2 - Aug 2nd, 2006, 10:31pm
Thanks for the link you gave to me. Actually i am doing Two stage Op amp. I have decided the W/L of two differential nMOS but i am struggling with W/L of Active current mirror load for my Op amp.Can you plz tell me how to decide the W/L of active mos load in current mirror configuration. Also it wold be good if you send me some thing regarding ICMR & OCMR.
Amit Kumar Singh
Re: OP AMP design
Reply #3 - Aug 2nd, 2006, 11:08pm
You ought to decide the W/L of the active load that should meet the requirements of linearity, output swing, slew rate, gain, matching, noise, etc. Eventually it depends on your spec, maybe some are important, and something like noise could be omitted.
I remember Paul Gray had a paper on JSSC in 1970s.  MOS OPAMP tutorial or something like that. Smiley
amitsingh
Bangalore, India
Re: OP AMP design
Reply #4 - Aug 3rd, 2006, 5:46am
Its great you are taking intrest in helping me.
Can you mail that link of Paul Gray.
I am working on 130nm process. I have specs like SR=20v/us, ICMR=.8,PM=60 deg, GM 70 db,UGB=80Mhz.
Plz send me the link from where i can find how to deal with all specs and decide parameters.
Thanks Smiley
Amit Kumar Singh
jeffyan
Re: OP AMP design
Reply #5 - Aug 3rd, 2006, 6:05pm
i think you'd better go to read allen's book,  very detail analysis to op-amp was performed.
the other thing is your process is .13,so some thing like short channel effects must be considered.
good luck. Shocked
Re: OP AMP design
Reply #6 - Aug 3rd, 2006, 7:17pm
I am sorry that I made a mistake. That paper is named MOS operational amplifier design-a tutorial overview
by Paul Gray and Robert Meyer, JSSC, Volume 17,  Issue 6,  Dec 1982 Page(s):969 - 982 .
amitsingh
Bangalore, India
Re: OP AMP design
Reply #7 - Aug 3rd, 2006, 9:42pm
Thanks a lot i found the papers on IEEE site.
Its quite helpful. Cheesy
Amit Kumar Singh
amitsingh
Bangalore, India
Re: OP AMP design
Reply #8 - Aug 8th, 2006, 11:25pm
Hi
    I am finished with my basic opamp design. My design has 75+db of gain, 56Mhz UGB and SR is 50v/us.
So now i want to characterize it, like CMRR, ICMR,PSRR,Offset and noise.
Please tell me how to achieve these values as per my spec.
Amit Kumar Singh
jbdavid
Re: OP AMP design
Reply #9 - Aug 11th, 2006, 2:45am
In Cadence Environment, I put together a rather basic tutorial on this, presented at the 2001 Cadence User Group.. Its now a white paper on the cadence website..
http://www.cadence.com/whitepapers/FVofDiffOpAmp_wp.pdf
The slides were presented at a couple of IEEE meetings and I found them (aint google great?)
at
http://engr.smu.edu/orgs/ssc/slides/20001215b.pdf
you might find them helpful..
Feel free to ask questions about the specifics here..
Jonathan
jbdavid
amitsingh
Bangalore, India
Re: OP AMP design
Reply #10 - Aug 17th, 2006, 6:37am
hi Jonathan
              Thanks for the link you send to me.Actually i was out of town for quite sometime thats why i couldnt reply to you. I am getting following specs. You plz tell me how to improve PSRR? because the PSRR i calculated is degrading as the frequency of Operation goes into MHz range.
                      SPECIFICATIONS   Obtained OPEN LOOP      CLOSED LOOP
GAIN                               > 70 db        76db
GAIN BAND WIDTH               >40MHZ        56MHZ                         60 Mhz
PHASE MARGIN               > 60 deg        60 deg                         55 deg
ICMR                               >.8      v        1V
CMRR                               > 60 db        88db
SLEW RATE            >20 V/us                                         36V/us
RANGE OF OPERATION      2 / 5 Mhz                                2Mhz
Output Offset                                                    .00012V
Input Offset                                                    .00000395V
PSRR                            >80db                                                   82db
Amit Kumar Singh
Re: OP AMP design
Reply #11 - Aug 17th, 2006, 11:03am
Your CMRR and PSRR will also go down as you introduce mismatch into the elements.
Start with either Monte Carlo (if you have statistical models) or do some small geometry mismatches and you will see them get worse.
The reason your PSRR is getting worse at higher frequencies is due (probably!) to the fact that capacitance coupling is more of an issue at higher frequencies and it is coupling through your PMOS active loads into the signal.
Also, don't forget to check PSRR with respect to ground noise as well.
Jerry
