Jul 16th, 2024, 11:43am
Post-processing capabilities in Verilog-AMS/Spectr (Read 3422 times)
Faisal
Aug 03rd, 2006, 9:20am
Are there post-processing capabilities (like plotting etc) available in Verilog-AMS or Spectre? I collect some data during my simulation in an array that can be dumped into a file. I would like to visuliaze this data by plotting it in waveform ?
Faisal
Re: Post-processing capabilities in Verilog-AMS/Sp
Reply #1 - Aug 4th, 2006, 3:57am
Verilog-AMS is a language, not a tool ...
wavescan is Cadence's new waveform viewer for their simulators.
mady79
Reply #2 - Aug 17th, 2006, 8:10am
you can try simvision as well...
jbdavid
Reply #3 - Aug 29th, 2006, 11:36am
there are no plotting functions actually IN either simulator..
and neither AWD, wavescan nor simvision do a very decent job showing you the value(s) of an array.. but if  you collect these from a variable over time you can plot the value of the variable during the simulation..
or make sure you format your output ( or reprocess it with perl or python) for you favorite external tool.. (python has some plotting functions available, so I guess Perl does too.. ) or you can format as a CSV file or XML and pass it to Matlab, openOffice or (gasp)  :-X MSExcel..
jbd
jbdavid
