jbdavid
there are no plotting functions actually IN either simulator.. and neither AWD, wavescan nor simvision do a very decent job showing you the value(s) of an array.. but if you collect these from a variable over time you can plot the value of the variable during the simulation.. or make sure you format your output ( or reprocess it with perl or python) for you favorite external tool.. (python has some plotting functions available, so I guess Perl does too.. ) or you can format as a CSV file or XML and pass it to Matlab, openOffice or (gasp) :-X MSExcel.. jbd
