Aug 23rd, 2024, 6:15am
MOSFET to generate 1 M Ohm - 60 M Ohm resistance (Read 2866 times)
avlsi
singapore
Aug 07th, 2006, 9:17pm
Is it possible to generate a resistance between 1 M Ohm - 60 M Ohm using a MOSFET structure. It should be linear. I tried with the architecture given in Ken Martin book( MOSFET - C filters) and also from prof. Tsividis papers. But I am not able to get a good linear resistor.
Help me out.
Thanks in advance.
Winners never Quit,Quitters never Win
vivkr
Re: MOSFET to generate 1 M Ohm - 60 M Ohm resistan
Reply #1 - Aug 9th, 2006, 11:45pm
Where do you need to use these linear resistors and how linear do you need them to be?
I can think of the following few examples, although they are all a little different from each other in terms of context:
1. Large Ron (upto 100 MOhm) using CMOS: Vittoz et. al., JSSC, June '88 (High Performance, Crystal Osc..., Section IV)
2. Linear current division: Bult, Geelen, JSSC, Dec. '92(An Inherently Linear & Compact Current Division Technique)
3. Linear Gm: Gilbert, JSSC, Jan. '98, (The multi-tanh principle....); this is with BJTs but you can use MOS biased in weak inversion.
Hope this helps.
Vivek
avlsi
singapore
Reply #2 - Aug 10th, 2006, 6:39pm
Dear Vivek,
        Its nice to hear from you. But I can set the Vds to 0.1 V,so it is not a problem with Vds. But since It is a wide range, I am not able to acheive V-I linearity . I want atleast 40% i.e., for v = 1 then I=1 ,lly for V=40 I=40,after that its not required.
        I will go thru the papers u have suggested.
Thanks.
Avlsi.
Reply #3 - Aug 10th, 2006, 11:25pm
Could you post something on what you are trying to do with such a huge resistance?
As a general rule I never try to use anything larger than 200K-300K on a PCB, and probably not larger than 10-20K in a chip.
What are you trying to do?
thanks,
Jerry
