Aug 31st, 2024, 10:11pm
Hspice CMI(common model interface) (Read 714 times)
windknows
Aug 11th, 2006, 5:35pm
i'm using the Hspice CMI(common model interface) to add custom model to the lib, but the err msg comes that it can not find the CMI lisense
i do have the license for hspice to run the netlist simulation,
but it does not contain the CMI feature in the license file, where can i find the CMI license file?
Re:  Hspice CMI(common model interface)
Reply #1 - Aug 14th, 2006, 4:58am
If you don't have the license, then you need to contact your account rep / salesperson and see about buying it, I would expect.
