May 3rd, 2024, 3:25pm
How to creat a VCO model with jitter in VerilogA (Read 1491 times)
semitao
Aug 15th, 2006, 6:19am
Hello! Smiley
       I just read the Modeling Jitter in PLL-based Frequency Synthesizers by Ken Kundert. In this paper, there is a VCO model that includes accumulating jitter. But this model generates square waves, I want a VCO model generates sine waves. How can I modify this model to generate sine waves?
Best regards!
Re: How to creat a VCO model with jitter in Verilo
Reply #1 - Aug 15th, 2006, 8:32am
In the VCO model given in the paper replace the last line of the model,
V(out) <+ transition(n ? Vhi : Vlo, 0, tt);
with one that computes a sine wave based on the phase variable already present in the model.
V(out) <+ ampl*cos(phase);
semitao
Reply #2 - Aug 15th, 2006, 5:44pm
Thanks, Ken.
         I have tried this statement. When I used a 1V voltage as the input signal, the output of VCO is very strange. I don't know the reason.
Best regards!
Reply #3 - Aug 15th, 2006, 6:19pm
try putting a boundstep() function to assure that the simulator takes a reasonable time step. The boundstep should be no more than 0.1T.
semitao
Reply #4 - Aug 15th, 2006, 7:01pm
Thanks, Ken.
          I have tried your method, and VCO works. Thank you!
Best regards!
semitao
Reply #5 - Aug 15th, 2006, 7:07pm
By the way, why the model doesn't need the bound_step statement, when the VCO outputs the square waves.
Best regards!
Reply #6 - Aug 16th, 2006, 12:02am
The transition statement forces time points at the corners of the waveform.
semitao
Reply #7 - Aug 16th, 2006, 12:34am
Thank you! Wink
