Jul 18th, 2024, 4:19am
PSP MOSFET (Read 458 times)
nikunj
PSP MOSFET
Aug 18th, 2006, 9:22am
I want to simulate different MOSFET charactresistics(Id-Vgs,C-V,etc) through cadence spectre. i m using PSP MOSFET Model. i have installed this model library dynamically but haveing some problems on programming part(like creating netlist for how to swap VGS & VSB ...)
Can anyone help me....
Re: PSP MOSFET
Reply #1 - Aug 21st, 2006, 10:10am
Why do you want to swap Vgs and Vsb??
What programming language are you using?  Are you writing a perl script to generate a spectre netlist for the simulation?
nikunj
Re: PSP MOSFET
Reply #2 - Aug 22nd, 2006, 10:32am
I am looking for I-V(D.C) characteristics of MOSFET model. Say example for transfer characteristic I am plotting Id ver Vgs (range is 0 to 1v) for different values of Vsb.
More problem I m suffering from is Dynamic loading of MOSFET. I am using cadence spectre professional version in which PSP MOS MODEL is not there inside the tool. So I have installed dynamically. Installation is perfect but when I was running netlist it gave error like “devise is not recognize”
Do I need to make interface which behaves like handshaking between my library to cadence?? Or I need to generate KEY or CRACK the devise model for cadence?? If I have to do this then question is what is meaning of dynamic loading??
If you could give me some pointers, it will really help
nikunj
Re: PSP MOSFET
Reply #3 - Aug 22nd, 2006, 10:33am
Re: PSP MOSFET
Reply #4 - Aug 22nd, 2006, 1:05pm
What do you mean "installation is perfect"?
Do you have a .cmiconfig file that loads the appropriate libraries?  What do you see when you type "spectre -help psp1000"?  You should get something indicating what version of the SiMKit is being loaded, and then some documentation on the model.
nikunj
Re: PSP MOSFET
Reply #5 - Aug 22nd, 2006, 3:01pm
Correct....
.cmiconfig file is updated properly so when i will type this command spectre –h psp1010
I am getting msg
“This Device is supported within altergroups
This devise is dynamically loaded from the shared object
/home/gnikunj/SIMKIT_HOME/libsimkit_spectre_3.0.so”
Then synopsis and all documentation related to parameters will come.
Here I didn’t get any msg regarding to the version of simkit..
So what is problem? What u suggest…
nikunj
Re: PSP MOSFET
Reply #6 - Aug 22nd, 2006, 11:42pm
hey thanks  Geoffrey_Coram,
the problem is solved.. i was not including model code in netlist thats why it gave error
say for mos1100
#ahdl_include "mos11010.va"
is it possible to include 'c' code instead of verilog code in spectre netlist?
Looking forward to hearing from you...
Re: PSP MOSFET
Reply #7 - Aug 28th, 2006, 6:49am
Sorry for the delay in responding.
Please double-check your instance line and your model card.  You shouldn't need to #ahdl_include the Verilog-A source code.
Note you need a model, you can't do this:
m1 (d g s b)  psp1010 type=n ...
you have to do something like
m1 (d g s b) my_nmos l=1u w=1u
model my_nmos psp1010 type=n ...
nikunj
Re: PSP MOSFET
Reply #8 - Aug 29th, 2006, 11:19am
For Id-Vd char. Of PSP, I will get some typical results ….it looks like Id-Vg char nt Id-Vd..
Here I m considering Vgs=0.7v Vsb=0.0v & I m varying Vds from 0 to 1 v and corresponding measuring drain current
Netlist ://
simulator lang=spectre
VGs (g 0) vsource type=dc dc=0.7
VDs (d 0) vsource type=dc
M1 ( d  g  0  0 ) npsp w=10e-6 l=10e-6
model npsp psp1011 type=+1
dc1 dc dev=VD start=0 stop=1.0 lin=20
save VD:currents
when I will type spectre –f nutascii <filename> I will generate .raw data file also,
Title: // Spectre transfer char. circuit for psp1010
Date: 4:44:06 PM, Tue Aug 29, 2006
Plotname: DC Analysis `dc1': VDs:dc = (0 V -> 1 V)
Flags: real
No. Variables:        3
No. Points:       21
Variables:      0      dc      V
           1      VDs:n      A plot=0 grid=0
           2      VDs:p      A plot=0 grid=0
Values:
0      0      0      0
1      0.05      5.0000062717331e-14      -5.0000062717331e-14
2      0.1      1.0000049019495e-13      -1.0000049019495e-13
3      0.15      1.50003455393141e-13      -1.50003455393141e-13
4      0.2      2.00024022330751e-13      -2.00024022330751e-13
5      0.25      2.50166540052325e-13      -2.50166540052325e-13
6      0.3      3.01152020978476e-13      -3.01152020978476e-13
7      0.35      3.5796590224208e-13      -3.5796590224208e-13
8      0.4      4.55057471006125e-13      -4.55057471006125e-13
9      0.45      8.30365196150691e-13      -8.30365196150691e-13
10      0.5      3.12644373269282e-12      -3.12644373269282e-12
11      0.55      1.86746180781748e-11      -1.86746180781748e-11
12      0.6      1.25567730061252e-10      -1.25567730061252e-9
13      0.65      8.6099747370198e-10      -8.6099747370198e-10
14      0.7      5.89935901098427e-09      -5.89935901098427e-09
15      0.75      3.97065948524656e-08      -3.97065948524656e-08
16      0.8      2.44109423589462e-07      -2.44109423589462e-07
17      0.85      1.12858076768285e-06      -1.12858076768285e-06
18      0.9      3.4322256987129e-06      -3.4322256987129e-06
19      0.95      7.14847075844511e-06      -7.14847075844511e-06
20      1      1.17955670880355e-05      -1.17955670880355e-05
i think Datas are comming wrong..Can u suggest me where I m doing wrong???
Really Thanks a lot for your time and consideration.
Re: PSP MOSFET
Reply #9 - Aug 30th, 2006, 6:56am
nikunj wrote on Aug 29th, 2006, 11:19am:
Try
model npsp psp1011 type=n
nikunj
Re: PSP MOSFET
Reply #10 - Aug 30th, 2006, 8:50am
If I am not mistaken then
psp1010 is for global geometry scaling
psp1011 is for global binning scaling
psp1010e is for local scalling
As I am working with parameter extraction of PSP mos model using Genetic Algorithms and (Variations). For my first stage, I am considering only global geometrical model because I am interested in data coming from global geometrical parameters only.
Can u suggest me is there problem in model itself or somewhere I am doing wrong??
nikunj
Re: PSP MOSFET
Reply #11 - Sep 1st, 2006, 12:41pm
thanks lot for helping....problem is solved...i got cottect dc I-V curve
bye
Re: PSP MOSFET
Reply #12 - Sep 4th, 2006, 8:55am
Geoffrey_Coram wrote on Aug 30th, 2006, 6:56am:
Try
For some reason, "type=+1" selects a PMOS device, I believe.  I think the help for the device says to use n or p, so +1 is not really supported.  This is unrelated to your choice of scaling rules.
