Jul 18th, 2024, 6:33am
CV characteristic (Read 4290 times)
337see733
Singapore
CV characteristic
Aug 29th, 2006, 12:54am
Dear all,
I'm getting from Medici simulation result showing Cgb=Cbg. This puzzle me. These two capacitances should not be the same under any circumstances(except below threshold voltage), as they are related to different charges, the former is gate charge(or total charge) and the latter is bulk-charge, respectively.
Anyone have any experience to counter this problem? Thanks in advance.
View Profile gilbertsee   IP Logged
Re: CV characteristic
Reply #1 - Aug 29th, 2006, 10:09am
Improper distribution of capacitance in a transistor model, not getting the depletion and bulk capacitnace effects modeled correctly is a very common problem in foundry models.
Sorry, that's the reality. What foundry model set is this? TSMC and UMC almost always mess this up.
Jerry
337see733
Singapore
Reply #2 - Aug 29th, 2006, 6:04pm
loose-electron wrote on Aug 29th, 2006, 10:09am:
Jerry
It was a 2-D simulation results using Medici from Synopsys. Not really any model set in particular.
Reply #3 - Aug 30th, 2006, 6:42am
For a moscap structure, I would indeed expect Cgb=Cbg; the gate charge must be equal and opposite the channel charge for charge neutrality.
Have you partitioned the channel charge into d, s, and b parts?  Do you have Qd and Qs non-zero?  In a MOS, if Qd=Qs=0, then Qb = -Qg, and it seems you're back in the moscap situation ...
337see733
Singapore
Reply #4 - Aug 31st, 2006, 2:20am
Geoffrey_Coram wrote on Aug 30th, 2006, 6:42am:
Yes, my model has non-zero qd and qs at strong inversion. However, my confusion is not with the model, but rather the simulation results shown in MEDICI simulation. Please find the attached. The Cbg is following Cgb, at Vds=0, which i suppose to be different from what i thought. Though Vds=0, i suppose it will still be different as there are still inversion charge at Vds=0 and some parasitic effects, such as the overlap charge should be added to the gate-charge. This device is very short, about 90nm(channel length), overlap length=20nm. It seems to me that the parasitic charges due to overlap is not included in the gate? or is it included somewhere else???
« Last Edit: Aug 31st, 2006, 6:26pm by 337see733 »
