Jul 16th, 2024, 11:21am
How to creat a loop filter model in VerilogA (Read 140 times)
semitao
Aug 21st, 2006, 6:48pm
  I want to creat a loop filter model in VerilogA. I found most loop filter model use R and C component, but I try to use the laplace function to describe this model, is that feasible?
ACWWong
Oxford, UK
Re: How to creat a loop filter model in VerilogA
Reply #1 - Aug 22nd, 2006, 4:02am
yes, laplace function should work fine... i think there used to be a "hidden state" problem with it in spectreRF simulations, but this has gone away now...
jbdavid
Reply #2 - Aug 29th, 2006, 11:25am
One of the problems I had with La-place is the fact that is immutable once setup..
IE you Can't change the transfer function during the transient simulation.. which is a problem if you
can switch capacitance or resistance in or out of the circuit to adjust for process, thermal, variation,
or to handle different types of inputs... maybe not generally the case for PLL loop filters, but thats
not the only place where this might be used. I once developed 32 parallel laplace functions and picked the one
selected by the control signal (a bus) but today I'd use a differntial model and change the coefficients based on the control signals..
ie
logic [4:0] BW_control;
electrical cap;
always @(BW_control) begin
  C = cap_lsb * BW_control;
analog begin
  I(cap) <+ C*ddt(V(cap));
of course you might want to change the capacitance nicely (transition) and get I(cap) to behave correctly on the transition, but
you get the idea..
Jbd
jbdavid
