Apr 30th, 2024, 4:10pm
duty cycle requirement for the input of CDR (Read 4974 times)
dandelion
Aug 24th, 2006, 12:16am
In normal conditions, what is the requirements of the duty cycles or PWD(pulse width distortion) for the input of the CDR?The input is TTL/CMOS level.
Thanks fo the help.
Re: duty cycle requirement for the input of CDR
Reply #1 - Aug 24th, 2006, 10:14am
John:
CDR? Could you please define?
tnx,
Jerry
Reply #2 - Aug 24th, 2006, 1:17pm
CDR = Clock and Data Recovery. A key block in the receiver of a SerDes.
email_gz
gaoz.mail@gmail.com
Reply #3 - Sep 5th, 2006, 8:59pm
If you use only one of positive or negtive edge to Tx/RX , duty cycle ,I think , is not a big problem.
But If you use both positive and negtive edge to Tx/RX ,you should have a 50% duty cycle synchronous clock.
View Profile email_gz email_gz   IP Logged
Reply #4 - Sep 5th, 2006, 11:38pm
John,
For a CDR, duty cycle distortion(DCD) or PWD is a part of the deterministic jitter. It reduces the sampling window, which means a smaller eye.
The total jitter, deterministic jitter + ramdom jitter should be less than the a cycle. Normally we do not have a special requirement on DCD only.
Best regards,
Yawei
