Jul 20th, 2024, 12:32pm
How to perform stability analysis (Read 5675 times)
chviswanadh
Bangalore
Aug 24th, 2006, 7:23am
I am designning a Switching regulator of continuous current mode constant off time topology. I am using spectre simulator for simulations. How can I perform STb analysis for this?
I tried the method of breaking the loop and inserting a probe but it is not giving the right results.
please help me with this
Frank Wiedmann
Munich, Germany
Re: How to perform stability analysis
Reply #1 - Aug 24th, 2006, 9:01am
Take a look at http://www.designers-guide.org/Forum/YaBB.pl?num=1133514560 and the links given there.
fantusox
Reply #2 - Sep 8th, 2006, 8:16pm
   I am am doing the same project as you , I have difficulties in obtaining stability too. Did anyone manage to know how to break the stability? I have read the link but tried but fail.
jbdavid
Reply #3 - Sep 12th, 2006, 11:51pm
are you looking at stability during ON time or OFF time?
or do you have a model linear model that considers both?
Jonathan
jbdavid
chviswanadh
Bangalore
Reply #4 - Sep 13th, 2006, 12:30am
I need to find the stability for both on time and off time.
fantusox
Reply #5 - Sep 21st, 2006, 6:51am
I need to find the stability of off time only. Some of the papers I read do not teach how to do the simulation of open loop response of the circuit .
Reply #6 - Sep 21st, 2006, 8:14am
Chviswanadh,
 If you have access to SpectreRF, periodic stability analysis, pstab, was added in MMSIM61.
It performs stability analysis on circuits with periodic operating points. I have used it on similar
circuits and the results seem reasonable. That is the predicted phase margin seems to track the
phase margin predicted by the pulse response. BTW, you could also use periodic ac analysis and
back out the stability from the open loop gain and phase.
