Jul 20th, 2024, 2:23pm
how to extract flicker noise co-efficient (Read 2173 times)
avlsi
singapore
Sep 11th, 2006, 2:02am
HI friends,
         I would like to extract flicker noise co-efficients for NMOS and PMOS in 0.18 u m process.
Can u tell me,what is the procedure to do it in cadence(any automatic)
or else any test circuit.
Thanks in advance.
Winners never Quit,Quitters never Win
ACWWong
Oxford, UK
Re: how to extract flicker noise co-efficient
Reply #1 - Sep 11th, 2006, 2:09am
avlsi wrote on Sep 11th, 2006, 2:02am:
HI friends,
Thanks in advance.
I'm not quite sure what you  mean by "extract".
The flicker noise coefficients that Cadence(spectre?) will simulate are given in the foundry model files. Parameters like kf, af, noimod etc. You can look up the meaning and how they are used in the spectre model guide in your cadence installation path.
avlsi
singapore
Reply #2 - Sep 11th, 2006, 2:35am
      I want to know the Kf of NMOS and PMOS. How will calculate using some circuit,as we do for Vt,Kp,Lambda.
      We plot some curves and calculate for hand calculations. Similarly,is there any procedure to get the flicker noise co-efficient.
Reply #3 - Sep 11th, 2006, 10:10pm
If I understand the question, correctly -
You need to go into the lab and measure the transistor flicker noise in a defined test envronment, for multiple sizes of W and L and then fit the noise parameters measured to create the actual model parameters.
Is that what you are looking for?
Jerry
avlsi
singapore
Reply #4 - Sep 11th, 2006, 11:05pm
In fact, My question seems a bit misleading.
I meant, I want a circuit to simulate the flicker noise and then calculate from the graphs, Kf(flicker noise co-efficient)
We can get the flicker noise co-efficient from Model file itself.
Thanks for your comment.
Reply #5 - Sep 12th, 2006, 1:08pm
Why would you want to do this? Extracting a  model parameter from simulated graphs, when you have the models, seems a bit of an odd thing to do...
sck236
Reply #6 - Sep 13th, 2006, 4:57pm
For hand calculation, it may be useful if I can extract Kf from the simulated grapgh.
I heard that simulators use rather complex parameters of BISM for calculating noise.
This parameters are not useful in hand calculation.
Does anyone has answers? This question is also what I want ask.
ACWWong
Oxford, UK
Reply #7 - Sep 14th, 2006, 2:50pm
sck236 wrote on Sep 13th, 2006, 4:57pm:
It depends on which exact model of BSIM you are using and what setting your model gives (eg. flkmod or noimod etc) as to what euations it uses.
So for example BSIM4 (quite modern) model with flkMod=1 gives:
Flicker noise = (Kf*gm^2)/(Cox*W*L*Frq^Af), which is pretty straight forward especially as the model file will tell you what Af and Kf are.
But if you insist on simulating it, just do a noise simulation (voltage driving the gate of a common-source fet will do for example) and plot the the noise, and correlate (or "extract" as you say) Af and Kf, you'll end up with the same or close to those in the model file..... so i'm still not sure what the point would be ?
avlsi
singapore
Reply #8 - Sep 20th, 2006, 5:02am
Hi guys,
   I would like to enlighten you about the flicker noise co-efficient.
There are two formulas for flicker noise
1. simple using Kf and Af
2. using q,noia,noib,noic,ef .. etc
Generally for noimd= 1, simple formula is used. This is not accurate.
So for noimod flag = 2,3 , we use the complicated expression.
This u can refer in BSIM3 manual.
Can anyone tell me a circuit, to simulate this noise and extract the Kf. Because not all foundries give Kf and Af. they give noia,noib,noic,Em,Ef.
Thanks in advance.
ACWWong
Oxford, UK
Reply #9 - Sep 20th, 2006, 5:33am
avlsi wrote on Sep 20th, 2006, 5:02am:
Hi guys,
Thanks in advance.
There is no need to enlighten me. I know, and in fact mentioned it in several of my previous posts to look up the kf and Af noia noib noibc Em Ef etc in the model file and look up the equations in the model guide.
IF YOU LOOK AT YOUR MODEL FILE AND THE VALUES FOR KF, AF, MOIA, NOIBM, EM, EF ARE NOT SET THEN IT IS POINTLESS TO SIMULATE BECAUSE YOU NOT GET ANYTHING!! HOWEVER THEY ARE SET IS WHAT ANY SIMULATION WILL GIVE YOU!
If noimod is set to 2 or 3 it will still use the parameters given in the model file. Again if they are not set, then you will get nothing.
Also as i said in my previous post you can simulate a common source fet driven by a voltage source on the gate and do a noise analysis. You will get the noise plot which, HOWEVER THE MODELS HAVE THE FLICKER NOISE PARAMETERS SETUP, will give you a noise you want. You can then correlate the slope and intercpet of the graph using simple maths to correlate back to the PARAMETERS IN THE MODEL FILE.
rgds,
aw
avlsi
singapore
Reply #10 - Sep 20th, 2006, 5:43am
I didnot litterally mean "enlightning"
I take back that word.
Ok, u have told u can get Kf and Af from model file. But I am not having them in my model file. So wht can i do is simulate and then extract.
Thanks for ur concern.
ACWWong
Oxford, UK
Reply #11 - Sep 20th, 2006, 6:12am
avlsi wrote on Sep 20th, 2006, 5:43am:
so you don;t have af or kf, so the model will be using noimod 2 or 3 in which case noia noib etc must set for any simulation to valid. you can do a noise simulation of a common source fet and plot the output noise. the slope will give you an equivalent af, the intecept point will help you equate an equivalent kf. of course the noise you get is bias/area dependant. perhaps do a family of sims to see if using noia noib etc. give youa stable equivalent kf, af of a simple model.
