May 18th, 2024, 1:07pm
Best LVS tool for small, full custom blocks? (Read 109 times)
SplinterCell
Aug 29th, 2006, 10:55pm
Which among the two are best suited for performing LVS on small, full custom blocks (standard cells, I/O cells, small analog blocks...)? and Why?
a. Cadence Assura
b. Mentor Calibre
If anybody has used one/both of these tools, please share their experiences..
Thanks!
jbdavid
Re: Best LVS tool for small, full custom blocks?
Reply #1 - Aug 30th, 2006, 11:40pm
One of my best Layout guys says Calibre is Easier for his debug purpose..
From MY point of view, Assura is easier to get working on a Parasitic Resimulation
flow.. and has the VAVO tool set for the ElectroMigration/ IR drop analysis flow..
Cost of the tools makes a difference too..
Run times are significantly different too.
jbd
jbdavid
SplinterCell
Reply #2 - Aug 30th, 2006, 11:55pm
Hi jbd,
Yes, the difference is pricing is too significant to ignore.. Assura is much cheaper than Calibre.
The standard cell based full chip designers are mostly unanimous is their support to Calibre, but I see many analog / custom block / cell designers sticking to Assura..
Is this because:
a) Anyway the custom layout boys are dependent on the cadence environment for design/simulation/layout etc and hence probably they have better integration/support for Assura.
b) The comparatively smaller analog/cell designs do not need the level of sophistication that Calibre offers at a much higher price
By the way, do you have any opinion about Assura's ability/inability w.r.t handling the complex rules associated with 65/45nm processes?
Thanks a lot for your answers,
S/C
jbdavid
Reply #3 - Sep 2nd, 2006, 12:24am
No, I have no idea, (but is that why cadence brought out the PVS tool now?)
and I hope that I can focus on FUNCTIONAL Verification, rather than physical, that I hope
someone else can tell me which tools I can use, at that time!
jbd
jbdavid
