May 18th, 2024, 11:06pm
plot of gm ,ro (Read 951 times)
avlsi
singapore
plot of gm ,ro
Sep 05th, 2006, 7:57pm
HI,
 I am using Cadence . I would like to plot gm and ro with varying current. But I donot know how to plot them. I tried by it gives only @ a single operating point.
Thanksin advance
Winners never Quit,Quitters never Win
ACWWong
Oxford, UK
Re: plot of gm ,ro
Reply #1 - Sep 6th, 2006, 2:05am
avlsi wrote on Sep 5th, 2006, 7:57pm:
HI,
Thanksin advance
Doing parametric analysis will work fine.
please see the relevant previous post:
http://www.designers-guide.org/Forum/YaBB.pl?num=1147336739
aamar
Re: plot of gm ,ro
Reply #2 - Sep 6th, 2006, 6:08am
I do it in another way, inorder to plot gm,gds vs. Vds, I use the parameteric analysis too but in the following way.
you set your schematic to get the current tansfer c/cs. once against vds and once against vgs (I mean here the sweep parameter), as you can sweep just one of the too at once then you can set the other parameter to a constant value or use it as a parameter for your parameteric analysis.
regarding the gds it should be easy, after plotting your current curves one can use the derv function in the calculator to get the d(Ids)/d(Vds) which is your gds in this case for a defined Vgs value, and as I said you can set the Vgs as a variable and repeat the simulation for different values of Vgs (normally Vgs is predetermined in your circuit because it depends on your biasing) but what can be done is varying the length of the transistor as an example while keeping the W/L constant.
inorder to make the same for gm , we use the other curve Ids vs. Vgs and derive it to get gm but it is in this case gm vs. vgs , so inorder to translate it into gm vs. vds you have to run the simulation for Ids vs. Vgs for several different vds values say 10 as an example, so the deriviation will result in a family of curves all are gm vs. vgs but for different vds values, then you use the function value from the calculator to caluculate for you the gm values at a definit value of Vgs and plot this expression it will plot for you the gm vs. vds.
So in short you have 3 expressions which you can save in your analog enviroment and run it every time after running the parameteric analysis.
after getting your required gm,gds or gm/gds  you can go back and check for the current required to achieve these values (Ibias).
This solution doesn't need editing in the netlist.
best regards,
aamar
Re: plot of gm ,ro
Reply #3 - Sep 20th, 2006, 3:07am
There are quite a few posts on plotting gm versus a swept variable in this forum, with answers. I suggest you use the search facility of the forum.
