May 3rd, 2024, 10:36pm
IC analysis (Read 1880 times)
Venkateshr
Bangalore
IC analysis
Sep 07th, 2006, 4:07am
HI ,
     Is there any way to find out the offset of any block say comparator or opamp(openloop ckt) in the ic analysis and then proceed on to use the offset in the tran.
I am doing dc sweep and writing the value to file and using that as ic for tran.
i tried one way oscillation by connecting two contradictory pins and the solution will be available only if the op of comparator turn high so then I get the offset.
Similar to inverter connected to itself thru an and gate whose select is another signal and selct has to be zero to have some settling point for the whole ckt.
jbdavid
Re: IC analysis
Reply #1 - Sep 8th, 2006, 12:55am
See my white paper on "Functional Verification of a differential operational amplifier" on the Cadence website.
it explains how to do this.
jbd
jbdavid
