Aug 22nd, 2024, 5:17pm
pad model (Read 2587 times)
grosser
pad model
Sep 11th, 2006, 2:47pm
hello
Do i connect R in series with L or parallelly in simple pad model??
regards
uncle_ezra
Re: pad model
Reply #1 - Sep 11th, 2006, 6:00pm
You should have a resistor in series with an inductor to model the bondwire and a resistor in series to a capacitor to model the pad.
grosser
Re: pad model
Reply #2 - Sep 12th, 2006, 12:21am
uncle_ezra wrote on Sep 11th, 2006, 6:00pm:
thanks
How much R and C should i choose for pad model?
ACWWong
Oxford, UK
Re: pad model
Reply #3 - Sep 12th, 2006, 2:57am
C depends on the pad area and distance to substrate (ie which metal layer is at the bottom of the pad metal stack)
R depends on your process and layout. The process parameters needed are things like substate resistivity etc. Layout effects like where you put sub contacts will also matter. You can uses tools like ASITIC or other extraction tools to help you evaluate it.
