May 19th, 2024, 10:38am
What is $Vt for a ordinary diode in veriloga code (Read 5144 times)
gmadhavareddy
Sep 12th, 2006, 10:02am
I want to change the model of Schottky diode which is avilable in Cadence ahdlLib.
I want to know the $Vt and what $ indicates in veriloga code?
 Vd = V(vanode, vcathode);
`ifdef __VAMS_ENABLE__
     Id = I(<vanode>);
`else
     Id = I(vanode, vanode);
`endif
     // intrinsic diode.
     if (Vd < -5*n*$vt) begin
        if (Vd == -bv) begin
           I(vanode, vcathode) <+ -area*ibv;
        end else if (Vd > -bv) begin
           I(vanode, vcathode) <+ -area*is;
        end else begin
           I(vanode, vcathode) <+ -area*is*(exp(-(bv + Vd)/$vt) -
              1 + bv/$vt);
     end else begin
        I(vanode, vcathode) <+ area*is*(exp((Vd - rs*Id)/(n*$vt)) - 1);
     I(vanode, vcathode) <+ gmin * Vd;
     // capacitance (junction and diffusion).
     if (Vd <= fcp) begin
        Qd = tt*Id  + area*cjo*phi*(1 - pow((1 - Vd/phi), (1 - m)))/(1 - m);
     end else begin
        Qd = tt*Id + area*cjo*(f1 + (1/f2)*(f3*(Vd - fcp) + (0.5*m/phi)*
           (Vd*Vd - fcp*fcp)));
     I(vanode, vcathode) <+ ddt(Qd);
Re: What is $Vt for a ordinary diode in veriloga c
Reply #1 - Sep 12th, 2006, 10:04am
$vt is kT/q.
Reply #2 - Sep 12th, 2006, 12:33pm
The $ (dollar sign) is usually used for "system functions and tasks," ie, things the simulator handles:  $strobe, $fopen, etc.  Also $temperature, which is the simulation temperature.
gmadhavareddy
Reply #3 - Sep 28th, 2006, 8:11am
Thank you.
I have some more doubts to clarify clearly.
1) Is $vt represents threshold voltage or not?
2) If yes,  here in this verilog model, they used $vt same for both ordinary diode and schottky diode.
/Madhav
ACWWong
Oxford, UK
Reply #4 - Sep 28th, 2006, 8:35am
gmadhavareddy wrote on Sep 28th, 2006, 8:11am:
Thank you.
/Madhav
1) As ken said, $vt is kT/q, the thermal voltage. so NO $vt does not reperesent threshold voltage
2) .
jbdavid
Reply #5 - Sep 30th, 2006, 1:52am
$vt represents Vt   a "thermal voltage"
as most diodes have a forward Current
Id = Is exp(-n⋅Vd/Vt)
which of course comes from the carrier density equation (see "Physics of Semiconductor Physics" by S. M. Sze chapter 1)
kT/q shows up so often in device equations because of this that the early users decided this needed to be a "built-in" function.
because it depends on temperature it cannot be a "constant"
Jbd
jbdavid
