Aug 16th, 2024, 12:28pm
the problems  for design a RF PA (Read 3973 times)
juzi
Chengdu,China
Sep 13th, 2006, 8:44pm
I wanna to design a 2.4GHz CMOS PA on chip, now I have the TSMC 0.35um SiGe BICMOS model,
the RF MOSFET  Vbox=0.75V.
   when the input voltage bigger than 1V,  the parasitical diode between the source and the bulk is forward based, and the SiO2 is breakdown .
    Vbox=0.75V is because the tox is only 7.35nm, but if the tox is increasing, the fT of the MOSFET will be decreasing, which is unacceptable for a 2.4G circuit!!!
    can someone give me any advise?
ACWWong
Oxford, UK
Re: the problems  for design a RF PA
Reply #1 - Sep 14th, 2006, 4:18am
juzi wrote on Sep 13th, 2006, 8:44pm:
Firstly I don't see how you are forward biasing the source bulk diode. If its NMOS then the bulk is at ground. The source would need to go negative of ground for forward bias (in which case you are doing a very strange PA). If its PMOS then the you might suffer DRAIN to bulk diode forward bias due to over voltage swing on the drain. Is this what you mean ?
Secondly tox=7.35nm is thick, so Vbox should be a few volts. Can't see how it is only 0.75V. Maybe some mistake in the kit.
I am using tox ~2nm and Vbox > 1.5V in a digital CMOS process (so SiO2).
cheers
aw
juzi
Chengdu,China
Reply #2 - Oct 12th, 2006, 8:58am
oh, the Vbox=7.35V. It's too late today,I will post some pictures tomorrow.
juzi
Chengdu,China
Reply #3 - Oct 17th, 2006, 7:20am
I draw a subcircuit of the mosfet in the accessories. during the PSS, if the input voltage is more than 1V, there will be the warning:the SB jonction diode of mi is forward biased at some moment.
dragonnj
Reply #4 - Oct 26th, 2006, 7:37pm
Maybe I met the same problem like you. Try to decrease the value of input port's amplitude(dBm), not the AC magnitude.
When I use PSS to sim P1dB, first I set the sweeping variable prf from -20 to 20, then PSS warning me the biopolar is game over. After I decrease the prf from -50 to 0, everything is OK.
Hope it is help to you.
