Jul 24th, 2024, 11:20am
RMS power VS Average Power (Read 6873 times)
chase.ng
penang/malaysia
Sep 14th, 2006, 6:28pm
Consider a simple inverter feed with a clock at a certain frequency. Which is the correct way to calculate the power dissipation? and why?
a. rms(VDD(t)) * rms(IDD(t))
b. average(VDD(t) * IDD(t))
where VDD is the supply voltage, IDD is the supply current.
thanks,
chase
Chase
View Profile chase.ng   IP Logged
ACWWong
Oxford, UK
Re: RMS power VS Average Power
Reply #1 - Sep 20th, 2006, 5:09am
chase.ng wrote on Sep 14th, 2006, 6:28pm:
thanks,
chase
The mean power disappation is a. Vrms*Irms. To be strict the Real average power is REAL(Vrms*Irms).
With b. you can get zero power for ac signals centred on zero.... which isn't correct
cheers
aw
chase.ng
penang/malaysia
Reply #2 - Sep 20th, 2006, 10:49am
Thanks aw, but I have further question.
Assume a square wave voltage source with 50% duty cycle, connected to a resistor in series. Then I will agree that the mean power will be the product of rms voltage and rms current.
However for an inverter, assumed clocked at 1/T and at supply voltage V, therefore the charge Q, being dumped into the ground is C*V every T seconds. Therefore energy being dissipated per cycle is Q*V, power, P = Q*V/T. Since Q = ∫I dt, then power, P = 1/T *∫I dt * V. Isn't it the 1/T * ∫I dt = average current instead of RMS current?
Can anyone clarify that?
chase
« Last Edit: Sep 20th, 2006, 1:50pm by chase.ng »
Chase
ycj
Hsin Chu, Taiwan
Reply #3 - Sep 21st, 2006, 8:09pm
Go and get the doc of the following link to have a complete answer:
www.eznec.com/Amateur/RMS_Power.pdf
Quick answer: rms(V)*rms(I) does not have any physical meaning. To calculate the power, just use Integral(P(t)*I(t))/T.
JSL
Sunnyvale, CA
Reply #4 - Apr 13th, 2011, 5:49pm
Short answer: do not use Vrms*Irms.
The correct answer to "how do I measure the average power correctly" is (b), average(V*I) for pin VDD, assuming that:
(i) the inverter has one supply VDD
(ii) the negative supply is tied to ground
(iii) there is no net power in/out of any other pin
More generally, the average power dissipated in a block with multiple pins will be the average of the sum of V*I on all pins:
PAVE= average( V1*I1 + V2*I2 ... VN*IN)
P=Vrms*Irms is true only for purely resistive (real) loads.  As a trivial counter-example, imagine that your block contains only an ideal capacitor and you drive it with a sine wave.
The paper at www.eznec.com incorrectly states that P=Vrms*Irms is always true, because it only considers a resistive load.  It makes a slightly different point, which is that the RMS value of (I*V) has no particular significance.  I would recommend this article instead:
http://en.wikipedia.org/wiki/AC_power
