Jul 19th, 2024, 6:23pm
Pipelined ADC (OTA Switching Load) (Read 1541 times)
packiaraj
India
Sep 21st, 2006, 9:00pm
            The OTA used in Flip around Sample and Hold Swiched Cap ckt would see a capactive load in sampling mode different from that in amplifying mode (In amplifying mode SHA is loaded by the first stage MDAC capacitors).
Naturally, we decide the OTA UGB and Gain based on the tolerable final settling error and finite gain error specifications. So, we take into account only the capacitive load in amplifying mode and NOT the load seen by OTA in sampling mode.
But OTA designed, in place, would see a less load in sampling mode, so UGB changes, but the non-dominant poles does not seem to move atleast for the first degree...hence PM changes... So a potential threat to the stability???  ::)
Any help that makes me understand this will be greatly appreciated!!!
Packiaraj.V.
Sarig
Re: Pipelined ADC (OTA Switching Load)
Reply #1 - Sep 29th, 2006, 2:08pm
Check if the Switch + sampling Cap does not create a pole which is close to UGB
