Oct 26th, 2026, 11:40pm
difference MIC and FDTD (+ crash) (Read 6345 times)
Paul Geraedts
GIGO
Enschede, Netherlands
Sep 22nd, 2006, 2:58am
Does anyone know where I can find details about the Finite-Difference Time-Domain refinement method as implemented in SpectreRF?
I have found a good article on the Multi-Interval Chebyshev refinement method already, but I would like to know when to use which. http://www.ieeexplore.ieee.org/iel5/6899/18566/00855300.pdf?tp=&arnumber=855300&...
As far as I understand, MIC is available in both forced and autonomous PSS and FDTD is only available in forced PSS.
I also found a bug in Spectre related to MIC; see the attached logfile.
When you reuse *unrefined* PSS data (so the periodic steady-state data itself as written with writePSS without having MIC enabled) while MIC is enabled, a segmentation fault results. It does not matter if you set checkPSS to yes or no.
Paul
Paul Geraedts
GIGO
Re: difference MIC and FDTD (+ crash)
Reply #1 - Sep 22nd, 2006, 6:16am
As it turns out, a work-around of the segmentation fault is reusing the already *refined* PSS data (instead of the unrefined PSS data). So enabling MIC in both PSS analyses. The periodic steady-state will get even more refined now, so basically it has the same result as decreasing psaratio.
Paul
byang
Reply #2 - Sep 22nd, 2006, 8:42am
Hi, Paul,
As the original developer of the method (some years ago), sorry for this kind usability issue and the crash. I am not with Cadence now. However, if you can send me your netlist, I can try to relay it to Cadence R&D to take a look. My e-mail address is [email protected].
The difference between finite difference method and shooting-Newton method is that the periodicity is enforced exactly in finite difference method. In shooting-Newton method, the solution after a period can differ by some error tolerance. MIC is high-order finite-difference method. If you want very low noise floor and high accuracy, it can help.
Baolin
Paul Geraedts
GIGO
Reply #3 - Sep 22nd, 2006, 10:26am
Hi Baolin,
Thanks for your quick reply! Don't worry about the crash, the work-around does the trick nicely. The netlist that I'm using contains a lot of stuff which I'm not allowed to pass on. Another similar example will probably show the same behaviour. Hopefully somebody from Cadence is reading this as well (Andrew? ;). But thanks for your offer!
Yes, MIC seems very useful. I've read somewhere that it can get the noise floor to levels of about -200dB! Great for oscillator design.
So am I right that FDTD, as implemented in Spectre, is a refinement method? So that always a (coarse) periodic steady-state has to be calculated first with Shooting-Newton (the combination Harmonic Balance & FDTD is probably a bit silly, right?). So MIC is as exact as FDTD (otherwise, why would you want to use MIC)?
I still don't really get when to use which method (FDTD/MIC). Could you give me some general advise?
I don't want to bother you too much with it though. Do you know of any good article on FDTD as implemented in Spectre?
Thanks again,
Paul
byang
Reply #4 - Sep 24th, 2006, 10:32am
Hi, Paul,
MIC, as it is implemented in SpectreRF, is one type of FD method. It is just that the integration method is Chebyshev method, which could be high-order, while non-MIC FD method is only up to 2nd-order (Gear or Trap method).
Jacob White and Ken Kundert's book on Steady State method has some information on the finite difference method.
Baolin
Paul Geraedts
GIGO
Reply #5 - Sep 24th, 2006, 1:19pm
Hi Baolin,
I've never understood that both methods are so similar! I think I'll use MIC exclusively from now on, as it seems to me that MIC is an improvement on all fronts. Or do I overlook situations in which using the 2nd-order method can have advantages?
I have seen the book that you mentioned in our library. I'll have a look at it.
Baolin, thanks for your posts. You have been a great help! (To get accurate information on these topics is pretty hard for a regular user as myself.)
Paul
