Aug 25th, 2024, 1:23pm
Starting up an oscillator in sim (Read 4715 times)
Nick
Sep 27th, 2006, 8:25am
Hi All,
I am designing an LC oscillator. To start it up, I ramp up the supplies to their final value and then apply a dumped isin current source on one of the tank nodes. I have noticed that below an amplitude value of the isin the oscillator does not start up, or starts up but fails to keep the oscillation. That value is around 10nA for this circuit. Can anyone advise me as to how low/high the isin source amplitude should be? What does it mean in terms of simulator that for some values of amplitude the oscillator does not start? I am using the gear2only method for the transient analysis.
Thank you,
Nick
Nick
bernd
Munich/Germany
Re: Starting up an oscillator in sim
Reply #1 - Sep 27th, 2006, 8:30am
Try with traponly.
Bernd
Just another lonesome cad guy
Nick
Reply #2 - Sep 27th, 2006, 8:37am
thanks for the reply.
Traponly and gear2only have the same results.
When using Euler, I need even larger amplitudes to get start-up, but I think that has to do with the method itself.
Any other ideas? Could it be circuit dependent?
Nick
Nick
bernd
Munich/Germany
Reply #3 - Sep 27th, 2006, 8:48am
Try to set an 'Initial Condition" of the value of your supply voltage to
the tank node rather then using an isin source.
Bernd
Nick
Reply #4 - Sep 27th, 2006, 9:42am
That doesn't work.
I have tried playing with initial conditions and also with vsin sources on the supply and on the tank.
Only the isin source seams to work. I apply it with a delay, after ramping up the supplies of the circuit to their final value. I cannot understand the dependence on the amplitude of the current though.
Nick
Nick
ACWWong
Oxford, UK
Reply #5 - Sep 27th, 2006, 12:13pm
Nick wrote on Sep 27th, 2006, 8:25am:
if you're using traponly and the LC oscillator starts but then the amplitude dies away, then i guess you don;t have enough negative resistance in your active core to overcome losses in your tank (ie you don't have a net negative resistance). you will find if you increase your negative resistance the oscillator will start easier in simulation (when given the current kick), as in real life. using gear or euler could kill the oscillation due to numerical damping.
as to the size of the kick, as oscillators start on noise, you could give it a kick in the order of the size of the noise you expect to give a better estimate of start-up time. although i normally give it just a big kick!
(aside: i think there is a fairly new transient noise function which could do this for you? i haven;t used it myself but might be worth looking into ?)
