Aug 17th, 2024, 12:19pm
about the pkg downbond inductor (Read 1845 times)
jeetchu
Sep 22nd, 2006, 6:01pm
for a simple one stage rf amplifier,such as LNA or driver,downbond inductor is used as the emitter degeneration .how much effection with the degeneration inductor on the gain and linearity?
I find the voltage gain is too sensitivity with the inductor value.the gain reduce 3dB when i set the indcutor from 0.5dB to 0.6dB.
ACWWong
Oxford, UK
Re: about the pkg downbond inductor
Reply #1 - Sep 23rd, 2006, 2:29am
Normally i would expect degeneration impedance increase of 20% to have the effect of reducing volatge gain by 1/1.2 (ie about -1.6dB) if gm*Zdegenertion>>1. Linearity would improve by a similar amount.
I think in your case you are having the additional impact of input mismatch (or at least change of input match) which is giving you the additional gain loss.
cheers
aw
