May 5th, 2024, 6:15am
Pole zero plot (Read 1433 times)
hande.vinayak
BOM
Pole zero plot
Sep 25th, 2006, 12:25am
Hello to all,
 I am designing a Folded OTA,please can anybody tell me how to plot a pole zero plot for finding a stability?
I am working on Cadence Analog Design Environment tool.
 Thanks.
                  Embarrassed
packiaraj
India
Re: Pole zero plot
Reply #1 - Sep 25th, 2006, 3:55am
Why do you want to see the PZ plot to determine the stability? I feel Spectre's STB analysis is far better than PZ analysis to simulate stability margins. PZ analysis will give only the location of Poles and Zeros (a lot of them actually!!!) and NOT the parameters Like Phase Margin and Gain Margin. PM and GM are the impotant stability parameters as they would tell you how far is your circuit from becoming unstable.
Packiaraj.V.
hande.vinayak
BOM
Re: Pole zero plot
Reply #2 - Sep 25th, 2006, 10:47pm
But as I am new this field,I wanted to know that while moving into the 'STB' anlysis.What we have to write into 'Probe Instance'----Block?I wanted to check open loop gain and open loop stability.
Thanks.
 Vinayak.
semitao
Re: Pole zero plot
Reply #3 - Sep 27th, 2006, 6:16pm
   Does anyone  have any tutorial about spectre PZ & STB analysis?
best regards.
Re: Pole zero plot
Reply #4 - Sep 27th, 2006, 7:26pm
Re: Pole zero plot
Reply #5 - Oct 28th, 2006, 7:22am
I sometimes use pz analysis to figure out if the circuit is unstable - because you can tell this without having to analyse specific loops - it will analyse the whole circuit.
However, if you want to get information about the amount of margin, then stb is the man for the job. In addition to the reference that Ken posted, I believe there is an application note on http://sourcelink.cadence.com . If you can't find it, file a service request, and your friendly Cadence application engineer can locate it for you.
Andrw.
hchanda
Re: Pole zero plot
Reply #6 - Nov 2nd, 2006, 6:01pm
Hi ken,
I am looking for the document that talks about the spectre stability analysis. I was seaching for it in the forum
and found the pointer to document mentioned by you (please see  below)
Background on STB: http://www.thekunderts.net/ken/docs/c%26d2001-01.pdf .
But I am not able find any document at that pointer. Could you please provide the pointer to document?
Hc
hc
Re: Pole zero plot
Reply #7 - Nov 2nd, 2006, 7:52pm
The paper has been moved to http://www.kenkundert.com/docs/cd2001-01.pdf.
