Aug 17th, 2024, 4:21pm
How to use multiple-input vcvsp in Cadence? (Read 2007 times)
dqiao
Sep 25th, 2006, 5:47pm
I am using a vcvsp component in Cadence, in which there are 4 controlling voltages and 1 output.  The file I am trying to use has 5 columns: columns 1:4 as input and column 5 as output.  But I got an error message when I ran a simulation using Spectre.  The message is "Syntax error in Piece wise linear transfer function file:...(file name)".   Does any one know the right format?  Thank you very much.
