dqiao
I am using a vcvsp component in Cadence, in which there are 4 controlling voltages and 1 output. The file I am trying to use has 5 columns: columns 1:4 as input and column 5 as output. But I got an error message when I ran a simulation using Spectre. The message is "Syntax error in Piece wise linear transfer function file:...(file name)". Does any one know the right format? Thank you very much.
