Jul 3rd, 2025, 7:27pm
many modules in one cell (Virtuoso-AMS)? (Read 2722 times)
Pavel
Lausanne/Switzerland
Sep 29th, 2006, 1:42am
Hello
Is it possible to create more then one module in cell.
When I do it, elaboration fails and error message appears:
*E,CUCFUN (No HDL source,0|0): instance 'I1' of the unit 'MOD2' is unresolved in 'MyLib.MOD1:verilogams'.
MOD1 consists of two MOD2.
In the cell MOD1 I created 2 modules: MOD1 and MOD2.
Thanks in advance.
Pavel.
bernd
Munich/Germany
Re: many modules in one cell (Virtuoso-AMS)?
Reply #1 - Sep 29th, 2006, 2:42am
I also saw this issue with AMS Designer when I was using
AMS Designer out of DFII with HED.
I had a Verilog file containing more than one module, specified as
'View to use from source file'.
I worked around it by importing the HDL code in a DFII library,
in my case with 'Verilog In',
then they appeared as separate modules and AMS Designer could evaluate them.
Bernd
Just another lonesome cad guy
jbdavid
Reply #2 - Sep 30th, 2006, 1:36am
Yep..
in cdba - one CELL = one Module
if you put another modele inside it needs its own module.. module name MUST match the cell name..
But this is NORMAL in verilog design.. one file per module (name.v) except gates which will all be in one library file lib.v
Of course, this is just standard practice in most places I've seen and not a requirement, and not quire often enough recommended to new users to keep it fairly universal..
jbdavid
