May 21st, 2024, 4:03am
latch up failure due to design ? (Read 3772 times)
jason_class
singapore
Oct 05th, 2006, 9:18am
Dear All
I need some help to understand more about latch up failure.
Usually, latch up failure happens are due to improper layout of design OR due to process issue?
I heard that often latch up failure happens in IO mos. What are they for? Why it is often the case latch up happens at IO mos? Is the W/L bigger than normal logic mos or some other reason?
If anyone has any good reference  on this topic, kindly share with me.
Thank you for your help.
best rgds
Jason
Re: latch up failure due to design ?
Reply #1 - Oct 6th, 2006, 3:33pm
most latch problems are due to poor layoutsw without sufficient substrate contacts or well tie ups.
I/O cells are more prevalemt to the problem due to the higher currents in the circuits
http://www.fairchildsemi.com/an/AN/AN-600.pdf#search=%22%22latch%20up%22%22
See the above - it is all about keeping the IR low enough so that you do not turn on the transistors (getting Vbe over 0.6 or there abouts)
Jerry
jason_class
singapore
Reply #2 - Oct 20th, 2006, 11:55pm
Dear Loose e-
Good link to share. Checking it out and will be back for more...
Jason
