Jul 17th, 2024, 6:28pm
latch up failure (Read 3217 times)
jason_class
singapore
latch up failure
Oct 05th, 2006, 9:28am
Dear All
Anyone can help to give some idea what could have cause latch up failure ? It is often mentioned the resistance of well are higher than normal. Am I right?
Other than well resistance, what is the other possible factor that contribute to latch up on mos devices?
Kindly enlighten
Thank you
best rgds
Jason
Re: latch up failure
Reply #1 - Oct 17th, 2006, 1:58pm
current thru the bulk, leads to an IR drop across the bulk, get that voltage drop above the Vbe voltage and you turn a parasitic transistor on.
Only got 2 variables to work with here I and R...
There's a lot of stuff out there on this. Google it.
jason_class
singapore
Reply #2 - Oct 20th, 2006, 11:54pm
Dear Loose e-
Thank you for the comment. I saw the other posting where you introduce a link to fairchild document. It is interesting to read..I have some doubts with the document. I shall write back later.
Jason
