Jul 18th, 2024, 10:05pm
Folded cascode opamp (Read 5996 times)
hande.vinayak
BOM
Oct 05th, 2006, 9:22pm
  I wanted to design a opamp with UGB 180Mhz with PM around 50 degrees and open loop gain 65dB.As per this spec. can you help me to decide a proper opamp config.If anybody is having a papera regarding folded cascode,can you like share with me?
  Thanks.
bharat
Re: Folded cascode opamp
Reply #1 - Oct 5th, 2006, 10:30pm
Folded cascode is preferred because of head room issue. If you are good in head room there is no need of folded cascode. I believe in KISS (keep it simple and small ) philosophy. Bias generation is little tricky in folded cascode.
-Bharat
hande.vinayak
BOM
Reply #2 - Oct 6th, 2006, 3:27am
Thanks Bharat.
          Can you suggest any paper in the case of Fully Differential FC OTA?
           Thnx.
Raul
San Jose, CA.
Reply #3 - Oct 10th, 2006, 2:25pm
Are you only driving capacitance? If so, a folded-cascode is the best option.
regards, Raul Perez
packiaraj
India
Reply #4 - Oct 11th, 2006, 8:40pm
Look for the attached JSSC paper on Fully Differential Folded Cascode OTA Design.
Packiaraj.V.
jbdavid
Reply #5 - Oct 11th, 2006, 11:07pm
Unless that was YOUR paper, its covered by an IEEE copyright..
ok even if it was its covered, but IEEE allows you to distribute a few copies of your own paper..
In either case,
posting it to a website like this is illegal!
It would be better to post a link
http://ieeexplore.ieee.org/xpls/abs_all.jsp?isnumber=1702&arnumber=45013&count=3...
jbdavid
hande.vinayak
BOM
Reply #6 - Oct 12th, 2006, 12:14am
Thanks Packiaraj.V.,it really helped me a lot.
packiaraj
India
Reply #7 - Oct 12th, 2006, 1:56am
I thought before posting....but ?... OK David... Taken...
Packiaraj.V.
SATurn
Reply #8 - Oct 12th, 2006, 9:17am
Please remind that if load capacitor is large, then it is very difficult to achieve the desired specs. In this case you must use another class of amplifier (e.g., class-AB) ...
