Quote:So cant we simulate verilogA code at unix command prompt??? (as verilog models can be through ncverilog)
You can't really like you are used from ncverilog.
You can simulate with VerilogAMS code form the command prompt
similar to NC-Verilog with Cadnence AMS Designer.
I don't know if this is also possible for Mentors ADVanceMS.
Quote:I am using Spectre simulator.
How can we simulate verilogA models at command prompt through spectre simulator??
You have to have a netlist which includes the VerilogA models.
Something like this:
ahdl_include "/<pathToYourLibrary>/libName/cellName/veriloga/veriloga.va"Then in principal you can simulate with Spectre
spectre <yourNetlist>Try 'spectre -h' from the command line.
Just to satisfy my curiosity why do you want to simulate VerilogA form the
command line with Spectre?
Bernd
