Jul 16th, 2024, 12:42pm
model of capacitor, controlled with voltage need (Read 5404 times)
stary
Oct 06th, 2006, 6:13am
Gurus, please, help me!
I want to use a voltage-controlled capacitor of type:
c = c0 + k*V(vc1, vc2)
here c0 and k are constants; vc1, vc2 - controlling nodes. So I try to describe it as:
I(vp,vn) <+ ddt( (c0 + k*V(vc1, vc2)) * V(vp,vn));   // (vp and vn are own nodes of capacitor)
But the compiler puts an error (rather long message). The main reason, as I understood, is mix of controlling and own voltages in one exepression. How it can be written in other form?
Re: model of capacitor, controlled with voltage ne
Reply #1 - Oct 6th, 2006, 10:30am
If you are asking us to interpret an error message for you, it is helpful if you include the message in your post. Even better would be to include your model and perhaps a test circuit that exhibits the problem as well.
Have you taken a look at http://www.designers-guide.org/Modeling/varactors.pdf?
stary
Reply #2 - Oct 8th, 2006, 10:54pm
Hi, Ken
I want to simulate a capacitor, linearly controlled with a voltage:
c = c0 + k*V(vc1,vc2)
here:
   c0 - initial capacitance,
   k   - a constant
   vc1, vc2 - the controlling nodes of capacitor
and this capacitor placed between nodes vp and vn. According to your paper I changed model of this capacitor on:
I(vp,vn) <+ ddt(c*V(vp,vn)+k*V(vc1,vc2)*V(vp,vn)*V(vp,vn)*0.5)
(i.e., I(vp,vn) is calculated via charge-based model.)
Again I get an compiler' error:
dynamic quantities must be linearity accessible.
What is the reason of error and how it can be fixed?
Reply #3 - Oct 8th, 2006, 11:38pm
I don't know. Your model seems fine to me. What does your vendor say?
stary
Reply #4 - Oct 9th, 2006, 12:29am
Oh, Ken, you don't sleep?!
Unfortunately, no access to vendor.
If it can help, the full text of model is:
`include "discipline.h"
`include "constants.h"
model cap1 (vp, vn, vc1, vc2);
inout vp, vn;
input vc1, vc2;
electrical vp, vn, vc1, vc2;
parameter real c = 0;
parameter real k = 0;
analog
    I(vp,vn) <+ ddt (c*V(vp, vn) + k*V(vc1, vc2)**V(vp, vn)*V(vp, vn)*0.5);
Reply #5 - Oct 9th, 2006, 6:09am
stary wrote on Oct 9th, 2006, 12:29am:
s/model/module ?
Did you intend the ** in there?
My compiler has no problem with the module.
stary
Reply #6 - Oct 9th, 2006, 6:21am
Yes, I did mistake when typing this text here, valid line is:
I(vp,vn) <+ ddt (c*V(vp, vn) + k*V(vc1, vc2)*V(vp, vn)*V(vp, vn)*0.5);
Version of software is: Virtuoso 5.1041_USR3.27.30
I cannot say exactly - s/model/module. It is a model of one of circuit's block.
Reply #7 - Oct 9th, 2006, 8:06am
This appears to be a bug in the simulator. I was able to work around it by assigning the argument of ddt() to a local variable, and then applying ddt() to that variable. So in particular, I used
module cap1 (vp, vn, vc1, vc2);
inout vp, vn;
input vc1, vc2;
real q;
analog begin
    q = c*V(vp, vn) + k*V(vc1, vc2)*V(vp, vn)*V(vp, vn)*0.5;
    I(vp,vn) <+ ddt (q);
and it compiled without finding any errors.
