Apr 27th, 2024, 9:50pm
Problem with pole setting in verilogA (Read 45 times)
chviswanadh
Bangalore
Oct 11th, 2006, 10:23pm
I am designing an OpAmp.
For setting the poles I am using Laplace_nd. I am having a problem here, for whatever pole frequency I am setting while designing, the AC simulation is giving a pole at 1/10th of the modelled pole frequency.
For example
I have set pole frequency at 2MHz in the following statement
V(vout) <+ laplace_nd((gain*V(inp,inm)), {1.0}, {1.0, 5.0e-7});
while performing AC analysis with the above I am getting a pole at 200KHz
The same way I have verified for different cases in each case it is giving 1/10th of the desired.
Am I analyzing it correct? or is it a problem with the code
Please give some inputs on this
Chviswanadh
Re: Problem with pole setting in verilogA
Reply #1 - Oct 12th, 2006, 4:30am
1/10 or 1/(2 pi) ?  I believe the polynomial is in angular frequency ω = 2 π f.
