Jul 1st, 2024, 2:10am
N2PORT DC problem (Read 5391 times)
uncle_ezra
N2PORT DC problem
Oct 12th, 2006, 1:58am
I have s-parameter data of a balun and tried importing into spectre using N2PORT. However when I run simulation it cannot give me the correct DC value. I have ran the s-parameter data down to 0 Hz but the problem persists. Is there a way around this problem, other than use another tool such as ADS?
vara
Re: N2PORT DC problem
Reply #1 - Oct 12th, 2006, 4:39am
Uncle,
Try 'rational' for the interpolation method in the 'n2port' instance.
I had to import from an other tool like you did and it works for me
in ac analysis.
However, for Transient analysis, 'rational' does not work and i read
somewhere (don't remember where) that 'spline' should be used.
Vara
vara
Reply #2 - Oct 12th, 2006, 4:44am
See attachement
uncle_ezra
Reply #3 - Oct 12th, 2006, 5:49pm
Thanks, I tried using 'rational' but it did not work. Basically what I have is a balun where in the primary one port is connected to VDD and the other to the signal and the secondary is a differential output. So when I run transient or DC analysis I get garbage since there are no DC voltage or current flowing from VDD to the main circuit.
madengr
Reply #4 - Oct 13th, 2006, 2:04pm
I noticed you are using Sonnet.  It will export a lumped element equivalent circuit that may work, assuimg it generates a low-pass structure.
Reply #5 - Jan 15th, 2007, 2:32am
Bit late in replying, but probably I would suggest using spline or linear as the interpolation method. I'd also recommend setting "Use smooth data windowing" to "yes" - this is nearly always the right thing to do; failure to do this often leads to an error in the DC value (but is more accurate if you have signals close to the maximum frequency in the s-parameter data).
There is an application note on sourcelink (search for "nport application note") which covers the parameters well.
