aaron_do
Hi aw,
can you elaborate on your last point? I thought since sampling occurs in the time-domain, it is basically frequency independant. i.e. if you must consider all noise within the filter bandwidth.
In my design, the IF is 2 MHz and the signal bandwidth is 1 MHz. The channel spacing is 5 MHz, so I originally thought that I could simply use a low pass filter for channel selection. This is because none of the unused channels will mix down to a frequency below the IF. After rethinking it I decided that the low frequency noise must be rejected due to the time-domain sampling but what you are saying seems to refute this.
One more thing. Based on the required BER, we can calculate the pre-ADC SNRmin. However the DSP can provide brickwall filtering. Will this DSP filter remove out of band noise and therefore relax SNRmin, or does SNRmin strictly apply to the circuits preceeding the ADC?
thanks for your help, Aaron
