There's a percent-code, I think %m or %M, that is supposed to give you the hierarchical instance name when used in a $fprintf call.
I'm not sure if the code would also be available for $sprintf, or even if $sprintf is available to you, in order to make a filename string using the instance name.
And you might need to "fix it up" if the hierarchy specifiers are not valid as filenames.
