Dear all,
I am using cadence 5.0.33 and DRC runs fine without any errors (but there are some warnings like "layer purpose fair does not exist in the tech file"). When I try to extract the layout I get the following error.
Quote:Extraction started at Wed Oct 18 14:57:13 2006
Assuring hierarchy instantiation for:
library: TestBench_kamva881
cell: sramcell_test
view: layout
Rules source is a simple file.
Rules path is /sw/cadence/libraries/HCMOS8D//DK_hcmos8d_4.0/Opus/DK_hcmos8d/divaEXT.rul.
Inclusion limit is set to 1000.
Parsing drcExtractRules of "/sw/cadence/libraries/HCMOS8D//DK_hcmos8d_4.0/Opus/DK_hcmos8d/divaEXT.rul"...
warn: Layer Purpose pair ("contact" "markerR") does not exist in the tech file.
contactR = geomGetPurpose("contact" "markerR")
warn: Layer Purpose pair ("v1" "markerR") does not exist in the tech file.
vi1R = geomGetPurpose("v1" "markerR")
warn: Layer Purpose pair ("v2" "markerR") does not exist in the tech file.
vi2R = geomGetPurpose("v2" "markerR")
warn: Layer Purpose pair ("v3" "markerR") does not exist in the tech file.
vi3R = geomGetPurpose("v3" "markerR")
warn: Layer Purpose pair ("v4" "markerR") does not exist in the tech file.
vi4R = geomGetPurpose("v4" "markerR")
error: Layer cp1nwC is not a device recognition layer.
attachParasitic(nc1 "nc1" cp1nwC)
attachParasitic(nc2 "nc2" cp1nwC)
info: If short location check is desired later on, check the saveInterconnect statement for correctness:
Interconnect layer mim5, epict, epitie, ndifct, pdifct, dpct, dnct, pstrct, nstrct, subct, subtie not saved.
Interconnect layers merged on save: lilint, lilctp, lilcta.
Interconnect layers merged on save: pstrap, dpter, pdifsi.
Interconnect layers merged on save: nstrap, dnter, ndifsi, sali.
Interconnect layers merged on save: vimim5c, vi5c.
Errors exist in the rules file "/sw/cadence/libraries/HCMOS8D//DK_hcmos8d_4.0/Opus/
Verification program terminated."".
Could you please throw some light on where the problem could be. I am using HCMOS8D (0.18u tech) as is evident above.
Thanks and Regards,
Kamesh.
