Jul 16th, 2024, 10:50am
Assura DRC checking with logical functions (Read 1759 times)
haikom
Nov 1st, 2006, 2:45am
I'm writing Assura DRC rules. The simple width and spacing checks are working, but I dont have a solution if I have two conditions. For example:
Metal1 rule: spacing < XX if width > YY. I thought it can be solved like this:
drc(Metal1 (sep<XX && width > YY) "Metal1 spacing error")    ; because in the Assura DRC docu it is mentioned that the rules follows the SKILL syntax
... but Assura dont want to compile this rule.
Has someone a solution for this?
Thanks in advance,
haikom
« Last Edit: Nov 01st, 2006, 11:30am by haikom »
View Profile haikomo   IP Logged
