Jul 16th, 2024, 10:46am
Error while extracting layout (Read 2835 times)
kamesh419
Oct 18th, 2006, 5:19am
Dear all,
 I am using cadence 5.0.33 and DRC runs fine without any errors (but there are some warnings like "layer purpose fair does not exist in the tech file"). When I try to extract the layout I get the following error.
Quote:
Extraction started at Wed Oct 18 14:57:13 2006
Assuring hierarchy instantiation for:
library: TestBench_kamva881
cell: sramcell_test
view: layout
Rules source is a simple file.
Rules path is /sw/cadence/libraries/HCMOS8D//DK_hcmos8d_4.0/Opus/DK_hcmos8d/divaEXT.rul.
Inclusion limit is set to 1000.
Parsing drcExtractRules of "/sw/cadence/libraries/HCMOS8D//DK_hcmos8d_4.0/Opus/DK_hcmos8d/divaEXT.rul"...
warn: Layer Purpose pair ("contact" "markerR") does not exist in the tech file.
contactR = geomGetPurpose("contact" "markerR")
warn: Layer Purpose pair ("v1" "markerR") does not exist in the tech file.
vi1R = geomGetPurpose("v1" "markerR")
warn: Layer Purpose pair ("v2" "markerR") does not exist in the tech file.
vi2R = geomGetPurpose("v2" "markerR")
warn: Layer Purpose pair ("v3" "markerR") does not exist in the tech file.
vi3R = geomGetPurpose("v3" "markerR")
warn: Layer Purpose pair ("v4" "markerR") does not exist in the tech file.
vi4R = geomGetPurpose("v4" "markerR")
error: Layer cp1nwC is not a device recognition layer.
attachParasitic(nc1 "nc1" cp1nwC)
attachParasitic(nc2 "nc2" cp1nwC)
info: If short location check is desired later on, check the saveInterconnect statement for correctness:
Interconnect layer mim5, epict, epitie, ndifct, pdifct, dpct, dnct, pstrct, nstrct, subct, subtie not saved.
Interconnect layers merged on save: lilint, lilctp, lilcta.
Interconnect layers merged on save: pstrap, dpter, pdifsi.
Interconnect layers merged on save: nstrap, dnter, ndifsi, sali.
Interconnect layers merged on save: vimim5c, vi5c.
Errors exist in the rules file "/sw/cadence/libraries/HCMOS8D//DK_hcmos8d_4.0/Opus/
Verification program terminated."".
Could you please throw some light on where the problem could be. I am using HCMOS8D (0.18u tech) as is evident above.
Thanks and Regards,
Kamesh.
Truth lies everywhere and partially even with the error.
bernd
Munich/Germany
Re: Error while extracting layout
Reply #1 - Oct 18th, 2006, 8:55am
My assumption;
You are either using a wrong
technology file or you do not have attached the right
technology file to your design library.
Or you have to define a specific switch for extracting you
layout with Diva. You can do this through the user interface.
Do you have any documentations or official support form your
design kit vendor, then you'd better consult them.
Bernd
Just another lonesome cad guy
