vivkr
Hi sugar,
Consider the fact that the gain and phase margin are measurements made at 2 frequencies alone, and for 1 value of feedback factor. How can they possibly convey all the relevant stability information of a Nyquist plot? Similarly, a Bode plot is still made for just 1 feedback factor.
Under certain assumptions, one may reliably extract stability information from the Bode plot. One basic assumption would be that the gain curve is monotonically decreasing or atleast not increasing. In such systems, there is typically a maximum value of loop gain (dc open loop gain A x feedback factor H) beyond which the loop becomes unstable.
On the other hand, your system has a range of gains (AHmin,AHmax) between which it is stable. This information though readily seen from a Nyquist plot is not seen in a Bode plot which is plotted for a single value of AH. Quite simply put, the Nyquist plot contains far more information than the Bode plot and the latter can never provide all the information about the former.
Does this answer your question?
Regards Vivek
