May 10th, 2024, 4:28am
Verilog-A: the meaning of gnd node? (Read 6769 times)
Pavel
Lausanne/Switzerland
Oct 19th, 2006, 6:44am
Hello
Simulating my schema in Virtuoso-AMS I observed non-desirable spikes on some signals.
I've tried to supress them with capacitors:
     capacitor #(.c(30p)) C1 (OutP);
     capacitor #(.c(30p)) C2 (OutN);
     capacitor #(.c(40p)) C3 (DacBuf_InP);
     capacitor #(.c(40p)) C4 (DacBuf_InN);
But if I restart the simulation with modified code, I receive internal error (see attachment).
Then I tried following:
       electrical gnd;
       ground gnd;
     capacitor #(.c(30p)) C1 (OutP, gnd);
     capacitor #(.c(30p)) C2 (OutN, gnd);
     capacitor #(.c(40p)) C3 (DacBuf_InP, gnd);
     capacitor #(.c(40p)) C4 (DacBuf_InN, gnd);
This time simulation runs, but spike don't disappear.
So my question is:
Are the instantiations:
 and
identical?
Regards.
Pavel
Re: Verilog-A: the meaning of gnd node?
Reply #1 - Oct 19th, 2006, 10:49am
Pavel wrote on Oct 19th, 2006, 6:44am:
 and
identical?
I don't think so.  I think the first one doesn't specify a connection for the other side of the capacitor, which would mean it is floating.  (Since this would have no dc path to ground, the simulator may put GMIN from the second terminal to ground.)
Pavel
Reply #2 - Oct 20th, 2006, 12:55am
Yes, is true. I checked it with simple example.
module GND_NODE_TEST;
electrical A, B, gnd;
ground gnd;
resistor #(.r(10)) R1 (A, gnd);
analog begin
     V(A) <+ 3;
     V(B) <+ I(A);
When I measure V(B) it's equal to -0.3V. When I instantiate R1 without gnd:
resistor #(.r(10)) R1 (A);
compilation passed, but simulation doesn't run and gives initialization error.
Regards.
Reply #3 - Oct 20th, 2006, 5:35am
In digital Verilog, leaving a port (terminal) unconnected is well-defined; it's treated as an unknown when an input and as high-impedance when an output.
Since Verilog-A is derived from Verilog, it has to follow the same rules.  It's a little strange when it iterfaces with Spice, though, because in Spice, terminals must be connected (generally - sometimes, as in BSIMSOI, there are extra terminals for self-heating that are connected conditionally on parameters).
jbdavid
Reply #4 - Oct 22nd, 2006, 10:43am
In Verilog-A
V(A) is the same as V(A,0)
where 0 is the analog simulators ground node.
If it is NOT behaving this way it is not complying to the LRM.
However your simulator may be using a different name for the ground node than you might expect.
if your simulators ground node is gnd! and you were using gnd in your models, then those are different nodes...  and you'll get "floating" nodes
so the problem may have been that ONLY those capacitors were connected to the simulators ground node, so it would be apparently floating.
Make sure you are using the SAME ground node as the analog simulator.
Jonathan
jbdavid
Reply #5 - Oct 23rd, 2006, 5:01am
jbdavid wrote on Oct 22nd, 2006, 10:43am:
In Verilog-A
Jonathan -
That's *not* the issue here.  I am sure the spice capacitor instantiated per Annex E uses the branch access V(A,B).  The question is: if you instantiate something in a Verilog netlist without specifying the connection to a port, what happens to that port?  (If you don't specify a parameter override, then the default is used, and the language requires a default in the parameter declaration.)
-Geoffrey
