Jul 18th, 2024, 12:24am
Pages: 1 2
Regulator Problem (Read 2578 times)
uncle_ezra
Regulator Problem
Oct 24th, 2006, 6:36pm
I have an on-chip amplifier followed by a Class-AB buffer driving an off-chip PNP in a feedback mode, providing a 3.3-to-1.8V regulated output. In my measurements the base of the PNP is railed to 3.3V on standy-mode and somehow have 180uA from emitter side (can PNP provide this current in cutoff region  :o). The base voltage moves to 2.5V when there is a large loading current. At both instances the collector is at 1.9V and emitter at 3.3V. Any suggestions on what is going on? In simulation everything seems ok at all corners even if I put a large input offset in the on-chip amplifier. Ideally I want the base voltage to be at 2.6V and collector at 1.8V in standy mode
ACWWong
Oxford, UK
Re: Regulator Problem
Reply #1 - Oct 25th, 2006, 2:36am
if everything you say is true... then i would say your pnp is device is broken... try replacing it.
if vbe is 0 and vce is > 0.3V then i can't see how 180uA flows into the emitter.... try testing the pnp alone to confirm.
uncle_ezra
Reply #2 - Oct 25th, 2006, 2:43am
Thanks for your reply.
I got a more sensible measurement today. Now my emitter sits at 3.3V, collector at 2.5V and base at 3.3V and no current flows! Seems like the feedback is not working properly. There might be something wrong with the connection on the PCB board ... still checking. One more thing, when I pull a large current from the collector the voltage pulls down to 1.9V and base move down to 2.6V.
ccd
Reply #3 - Oct 25th, 2006, 6:56pm
I'm thinking you could be capacitively loading your circuit when taking measurements causing your feedback not working.  How much capacitance is your probe?
uncle_ezra
Reply #4 - Oct 25th, 2006, 11:42pm
Hmm ... but with or without the probe there is no current, the BJT is off. I have placed a 30pF and 1MOhms loading in the simulation so it shouldnt be a problem. Still puzzled why the feedback is railing the base to 3.3V in standby mode and move down to 2.5V when there is large load current. Basically the BJT is going from cutoff to active region so its bound to oscillate when I go from standy mode to normal mode. Ideally in simulation the BJT should be in active region and remain there regardless of the mode of operation. Also I have added 22uF capacitor at the collector to add a zero for stability.
uncle_ezra
Reply #5 - Oct 26th, 2006, 12:58am
Would a multimeter load the collector? What kind of input impedance does a multimeter have?
ACWWong
Oxford, UK
Reply #6 - Oct 26th, 2006, 2:12am
uncle_ezra wrote on Oct 26th, 2006, 12:58am:
it should say what it is on the back... but usually they're 10Mohm... and if you can tolerate 30pF, then make sure you are using short (<0.5m) probe leads, then there shouldn't be a capacitance problem. If you're unsure you should use an oscilloscope, which has defined input R and C (typically 1Mohm//10pF on x1).
uncle_ezra
Reply #7 - Oct 26th, 2006, 2:13am
Yep I am using an oscilloscope.
ccd
Reply #8 - Oct 26th, 2006, 6:43am
I'm curious what your phase margin is between no load and large load.  I designed a linear voltage regulator before with mosfet driver and had to provide a dc path to ground as a minimum current load for loop stability reason. My phase margin decreases with lower current load.
Another question I have is since there seems to be some discrepancies between simulation and reality, so I'm wondering if you included the bondwire and such between the chip and the bjt in your simulation.
uncle_ezra
Reply #9 - Oct 26th, 2006, 6:02pm
Yep I have included all the bondwire and parasitics in the simulation. The phase margin are all above 80 deg in simulation. I think the main problem now is that the DC points are all wrong, so phase margin and everything is wrong. Not sure if it has to do with the BJT model since the manufacture does not provide one. I tried changing some of the spice paremeters and the DC point changes.
uncle_ezra
Reply #10 - Oct 30th, 2006, 9:06pm
Thanks for everyone's input. I found out that I needed a higher Q capacitor Grin
Does anyone know how to design regulator for higher ESR? What changes should one make in order to cope with lower Q capacitor? I found out that using a small signal analysis can be misleading in regulator design because even for high ESR >5Ohms the small signal tells me that the circuit is stable but if you run a transient it oscillates  :o
Reply #11 - Nov 2nd, 2006, 8:06am
The ESR of the load plays into the phase margin of the feedback system in a big way. What you are describing is a common problem in LDO regulators.
Jerry
uncle_ezra
Reply #12 - Nov 7th, 2006, 5:46pm
Has anyone experienced probing an unstable regulator and then releasing to find out it is stable ?????  :o  Anyone can explain this phenomena? I am still talking abt the same regulator described above. Basically probing either the base or collector I see oscillation on the oscilloscope when I powerup but then somehow it disappears after probing it. Seems like after pertubing the regulator becomes stable, totally confused ???
« Last Edit: Nov 8th, 2006, 1:19am by uncle_ezra »
uncle_ezra
Reply #13 - Jan 7th, 2007, 3:50pm
Attached is a single tone output of the LO. The tone seems noisy and the source was found to be from the regulator. As the current is increased further two "sidebands" seems to enlarge. Is the regulator unstable?
uncle_ezra
Reply #14 - Jan 8th, 2007, 5:03pm
I know the source is from the regulator. From the oscilloscope the output of the regulator is clean but maybe the harmonics are too small to be seen in an oscilloscope.
Pages: 1 2
