carlgrace
Terry,
Sadly, there isn't much you can do to lower the noise of a CMOS op amp aside from the obvious (passive loads, tons of current to get high gm in the input stage, etc.). Generally, you just optimize for noise, there aren't any fancy low noise topologies. Sorry. Adding devices adds noise, so the lowest noise structures are the simplest.
Regards, Carl
