Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 17
th
, 2024, 2:19am
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› PSRR simulation using PSS+PAC
Previous topic
Next topic
PSRR simulation using PSS+PAC (Read 4834 times)
ezencir
Irvine, CA
Oct 25
th
, 2006, 11:41am
Hello All,
Does anyone know how to simulate AM/PM PSRR using PSS+PAC of SpectreRF?
IP Logged
Re: PSRR simulation using PSS+PAC
Reply #1 -
Oct 25
th
, 2006, 12:07pm
Yes, of course.
What is your question? Does it concern the AM/PM, the PSRR, or the PSS+PAC?
IP Logged
ezencir
Irvine, CA
Reply #2 -
Oct 25
th
, 2006, 1:45pm
Hello Ken
When you do AC and XF to get PSRR you get the rejection performance for additive noise. If you would like to simulate the rejection to amplitude or phase modulating power supply disturbances you need to use PSS and PAC in conjunction. The question is how you do it? That is what I am asking.
Ertan
ezencir wrote
on Oct 25
th
, 2006, 11:41am:
Hello All,
IP Logged
Reply #3 -
Oct 25
th
, 2006, 4:40pm
You would specify pacmag=1 on your supply source, you would use the "modulated" version of PAC and select SSB/AM/PM. Run simulations. From Direct Plot, select PAC modulated, and plot AM and PM results.
IP Logged
Reply #4 -
Nov 7
th
, 2006, 7:59am
A comment on the circuitry if I may -
When a system is matched ideally, the PSRR results will look pretty good. For something more closely related to silicon, statistical mismatch of all elements (Monte Carlo) will give a more menaingful set of numbers.
Jerry
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
