Aug 17th, 2024, 4:09am
blocker requirements (Read 2843 times)
aaron_do
Nov 15th, 2006, 4:46am
I have some questions about intermodulation/blocker requirements. I read a paper on building a 802.15.4 compliant receiver, and the author listed the 802.15.4 specs. Some of them such as NF were calculated using the 802.15.4 standard's specs, and some of them such as minimum sensitivity and adjacent/alternate channel rejection were given by the 802.15.4 standard.
Anyway one of the specs was blocker level (-30 dBm), but when i read the 802.15.4 standard i found no mention of any blocker requirement. Does anybody know how blocker level is found? This -30 dBm blocker level imposes stricter requirements on the receiver linearity than the adjacent/alternate channel rejection...
Also, since the receiver must co-exist with other 2.4 GHz devices (Bluetooth etc) is it common practice for the receiver to be designed with stricter blocker requirements than those specified in the 802.15.4 standard?
thanks in advance,
Aaron
ACWWong
Oxford, UK
Re: blocker requirements
Reply #1 - Nov 15th, 2006, 7:08am
aaron_do wrote on Nov 15th, 2006, 4:46am:
I think this refers to ETSI (European telecommunications standards institute) spec EN 300 440.
Best thing here is to benchmark with the competition:
Try looking at datasheets from:
NordicVLSI
Chipcon
Jennic
etc.
cheers
aw
aaron_do
Reply #2 - Nov 15th, 2006, 5:56pm
Hi aw,
thanks a lot
Aaron
