Aug 15th, 2024, 6:30am
Variable Gain with table_model (Read 195 times)
bessib
Oct 30th, 2006, 8:56am
i want to model Gain Compression of a mixer caused by insufficient LO-Power with the table_model function. Here is my script and the table file:
             V(in)  <+ 50*I(in);        //50Ohms input
           Power_LO_Vsquared = pow(V(LO),2)/50;                                                   //determining LO-Power
           Power_LO_dBm = abs(10*log(1e-30+Power_LO_Vsquared/1e-3));              //conversion to dBm
           Gain_tbl_dB = $table_model(Power_LO_dBm, "mixer_gain_temp2.tbl","");   //loading Gain from file
           Gain_tbl_V = pow(10,Gain_tbl_dB/20);                                                     //conversion of Gain
           V(out) <+ Gain_tbl_V*V(in);        //weighting Input with Gain
#mixer_gain_temp2.tbl
#LO-Power(dBm)              Gain(dB)
0                        2.6
1                        3.6
2                        6
3                        5.6
4                        6.6
5                        7.6
6                        8.4
7                        9.2
The script reads out the correct Gain but unfortunately there must be a problem in mulitplying the Gain with the input voltage.
Can anyone help me?
Thanks!
Re: Variable Gain with table_model
Reply #1 - Oct 30th, 2006, 12:00pm
In line 2 V(LO) would be the instantaneous LO voltage. Probably not what you want.
bessib
Reply #2 - Nov 2nd, 2006, 7:47am
Thanks for your reply, Ken. Is there a way to extract the peakvalue of the voltage as a variable of type real?
Bessi
Reply #3 - Nov 2nd, 2006, 12:40pm
If you do, I think you'll end up with hidden state, the bane of RF simulations ...  But you are asking for some way to remember the past history of the model.  If you can save it to a node, rather than a real, then you might be OK.
Reply #4 - Nov 2nd, 2006, 8:39pm
Rectify and filter.
