Jul 17th, 2024, 7:23pm
question about PLL jitter (Read 863 times)
semitao
Nov 01st, 2006, 7:08pm
Hi,all.
   Who can tell me how to simulate the PLL jitter? When analyze the phase noise of VCO, we can use the Pnoise  in spectre.  I don't know how to analyse the noise from charge pump & PFD, anyone can help me?
Thanks in advance.
Re: question about PLL jitter
Reply #1 - Nov 2nd, 2006, 8:00am
Getting an accurate simulation of this is not an easy thing.
First - Ring Oscillator VCO or LC VCO?
semitao
Reply #2 - Nov 2nd, 2006, 9:03pm
Ring VCO
I am puzzled with how to select the charge pump current. As we know, the higher values of charge pump current lead to lower output phase noise. But the large current is limited by how large of capacitor values can be realized in the the loop filter implementation.
So, I have to decrease my pump current to get smaller capacitor, but I can't simulate the phase noise of detector to check the effect of new pump current. What can I do?
hchanda
Reply #3 - Nov 2nd, 2006, 11:24pm
Why do you need to reduce the capacitor if you are increasing the chargepump current? I did not follow your explaination.
hc
semitao
Reply #4 - Nov 5th, 2006, 5:49pm
Hi hchanda,
   I want to decrease the chargepump current to reduce my capacitor. my capacitor is 108pF, it's too large for my layout.
